Also if there is a low reservoir and no sign of leaking you could have a blown wheel cylinder in the back, check the interior of the rim for fluid or pull the drum off and give it a visual inspection.
Thanks to everyone for your input. after checking it was master that went out. I replaced and back on the road. i also topped it off with some fluid just to be safe, thanks again everyone.
