Help no Brakes
I was driving along and all of a sudden no brakes, had to use e-brake all the way home. pedal goes straight to the floor, any ideas? please help.
  • Have you checked your brake fluid reservoir? Perhaps your brake line broke somewhere.
    Check for leaks and your fluid level
  • what the others said, if all checks out suspect failed master, or the connection point at the pedal???
  • I had a leak and it turned out to be in the rear drum! Check for fluid somewhere!
  • Also if there is a low reservoir and no sign of leaking you could have a blown wheel cylinder in the back, check the interior of the rim for fluid or pull the drum off and give it a visual inspection.
  • epicbeatsepicbeats Band Wagon
    Happened in my ef.turned out the wheel cylinder seals burst.
  • GPsWagonGPsWagon Band Wagon
    Thanks to everyone for your input. after checking it was master that went out. I replaced and back on the road. i also topped it off with some fluid just to be safe, thanks again everyone.
