Please help a fellow Wagoneer out!!!
So I got to looking at my tranny the other day on my B16 with manual tranny and noticed there is two hoses coming from where the speedo cable goes in.. I was wondering what those hoses go to? My D15 auto tranny doesn't have them.
What do I do with these?
I sent my wiring harness to Rywire, and I just got it wired up, and I have two ecus, a PR3 and a PWO, which would be better? Also, they put a green plug on my injector resistor end, which is completely different from the gray one I have on my Injector box.. should I re-wire that into the gray plug? Or is it something I'm missing?
Does anyone have a fuel/vaccum diagram link?
I'll post picture of the progress later on.. It's going to be sweet.. If you are into the wagon type thing..
Sorry for so many questions, I just want to do everything right..
Again, good luck.
- Mike
the gray plug was used on obd1 resistor boxes and the green was used on obd0 boxes. If you have the male/female gray plugs, then I think you could just de-pin the wires in the green plug and add it to the gray plug.
IT'S GOING IN TOMORROW!!!!!!!!!!!!!!!!!!!!!!!
