Please help a fellow Wagoneer out!!!
So I got to looking at my tranny the other day on my B16 with manual tranny and noticed there is two hoses coming from where the speedo cable goes in.. I was wondering what those hoses go to? My D15 auto tranny doesn't have them.
What do I do with these?
I sent my wiring harness to Rywire, and I just got it wired up, and I have two ecus, a PR3 and a PWO, which would be better? Also, they put a green plug on my injector resistor end, which is completely different from the gray one I have on my Injector box.. should I re-wire that into the gray plug? Or is it something I'm missing?
Does anyone have a fuel/vaccum diagram link?
I'll post picture of the progress later on.. It's going to be sweet.. If you are into the wagon type thing..
Sorry for so many questions, I just want to do everything right..
  • HandofBoBHandofBoB New Wagonist
    I've always wondered what the hell those were for, I've always just grabed a hose and looped the two together. As for the resistor box having a grey plug never seen that. You can re-wire it/ re-pin it if you would like shouldnt be hard. Make sure you connect both yellow/blk wires from your DPFI to the input of the reisitor box. Dont know why but it makes it finiky if you dont. As for vacuum diagram check under your hood first, or you can go to honda and get a print out, or search on here, I saw manuals somewhere on this forum with it. Good luck with the swap. Going to be doing my auto-manual swap this weekend. To broke for a B-series swap. Tell me how the B16 is. Oh as for ecu's they are pretty much the same, I would definately keep both, incase you fry one.
    Again, good luck.
    - Mike
  • bwagonbwagon Band Wagon
    i think the hoses are for power steering.
    the gray plug was used on obd1 resistor boxes and the green was used on obd0 boxes. If you have the male/female gray plugs, then I think you could just de-pin the wires in the green plug and add it to the gray plug.
  • Thats what I plan on doing since the wires match the same colors or whatever..
    IT'S GOING IN TOMORROW!!!!!!!!!!!!!!!!!!!!!!!
    did you send rywire a dpfi auto harness, if so what did you swap to mpfi Bseries vtec manual? curious
  • Got it all fixed now! Thanks
