Don't need the magnetic plug.ALL Honda manual trannies come with a magnet inside.It's about 19mmx38mm.When u had your teg tranny apart u may have noticed it.
Even if u had used the BEST Oil it's not formulated for Smooth Shifting.
cant find a adaptor for the stock fanswitch!!!! :x
will the eng cooling temp sensor near the distibutor on the cylinder head work as a fan switch? coz it fits on the d16y7 block where the d16a6 fanswitch doesnt fit
:shock: If I'm right the switch you want to hook -up to.....is NOT the 1.That's the sensor that talks w/the ECU.She likes brainy types. The a6(wgn) fan switch is located near the oil filter.
Your fan switch moved to a better part of town.Those Honda engineers are on the ball. Your y7 FAN SWITCH is located on the thermostat housing where the raditor hose hooks up to.NOW she likes HOT fans. :twisted:
but there is something plugged into it already(near the dizzy) or will i extend the wires and tap it on that one?
u guys helped me alot here!
http://www.honda-tech.com/zerothread?id=1517787
o yeah! i didnt notice that my bad
