First swap
Guys could you help me on my first swap
i got a 1990 wagon with a crx si trans
96 dx d16y7
so what parts do i need to do this swap? do i need new axles, linkage, mounts, harness, etc.?
thanks! please guide me guys
here's some pictures of my swap
first i got a nice clean 1990 wagon
stock engine but its not working
picked up a d16y7 complete with tranny
FIRST OF ALL HERE ARE MY TOOLS :twisted:
after 4 hours all by myself i finally pulled down the engine!
then i cleaned the engine bay,
that's for today, not bad for a first timer
96 dx d16y7
i do suggest new oem mounts though, but they arent needed.
biggest problem is the engine harness? is it plug and play for the d16y7?
plus i wana use the IM and TB of the d16y7
im not good on electrical stuff
sorry d16y7 got no vtec
btw im usin a crx si tranny, could i use the flywheel and clutch that is currently on my d16a6 on my d16y7 block? is it direct bolt on?
Akiraboy was right about the engine.
The info I have is a little fuzzy.It depends on what year CRX Si tranny you have :?:Spline count. What size flywhl did the peeps put in when they swap in the CRX tranny :?: If they used the OEM clutch.It maybe smaller.This may not matter since you're working on a B18 swap
the crx si tranny is for fits on the dtock d16a6 (it came with the car when i bought it)
but i had to stop bolting the parts back coz it rained
Go Marc...!G :P Marc...!!
The EE9 will become the MARC-One-Eleven
8) :evil: :twisted: He .He.He!!!
btw about the temperature sending unit on the engine block for the d16y7 could i use the one on the cylinder head? coz the stock temp unit on the d16a6 is too big for the d16y7 block
Let's not confuse "old school" and "ghetto".
Whatever you call it, I'm impressed...that's really a hard way to do it.
You know that a lot of places rent engine lifts for really cheap?
Or heck, I just bought the engine lift.
They go on sale at Harbor Freight all the time. It was like $139.99. Its paid for itself many time over. If I charged $10 every time I loaned it to someone, I could have bought a second CRX.
but when i swap my rebuild b18c1 here im surely gonna have a lift coz i also need that to swap my coupe for a k20a :twisted:
guys any clues?
BTW using a pres plate and clutch from a crx si (for the trans) and using the stock d16y7 flywheel
Clutch plate installed backwards...used the CRX TO bearing?Pull lower clutch plate cvr off to see. :?
the car starts now!
only problem is the transmission coz eventhough i dont step on the clutch pedal it goes in gear and it makes a very strange sound :x
i installed the clutch plate correctly
used the CRX TO bearing?Pull lower clutch plate cvr off to see. :? >>> were is that?
is this the bearing? near the clutch? i dont recall having a bearing on it when i removed it?
BTW when i test drove the car i forgot to put the bolt on the driverside strut fork (got too exited
