How to remove rear egine mount?
Just wondering how the hell do I remove the rear engine mount? It looks like theres no way to get to the rear bolt. Am I missing something?
    u have to drop the crossmember down to get that last bolt i know exactly which one your talking about infact tonight i was looking at that bolt on my crx wondering why honda did that it makes no sense......
    :? DON'T need to drop cross member :!: I never have.
    neither have I. just get a wrench or socket wrench that will fit in there. now if its rusted solid then its a problem. other then that just some elbow grease should get it out.
    hhmm ive just dropped the cross member to get it out..... hhmm i guess i just never snaked a wrench in there.
    could be possible that the 2WD might be different then the 4WD :?:
  • I got it off. It wasn't near as hard as I figured it would be.
    I took a swivel end and a long extension and it came off the first try.
    b16 mount is on now. ;)
    RT4WD has the same mount to my knowledge. You don't take the mount point off just the bolt through the middle.
    You do when you are installing a B16a..
    Also, I read in a manual that that bolt is a "special bolt" and must be replaced if removed.. I don't know about that though.
    Oh in that case you'd need to cut it off i guess? When i looked at mine it looked like it had been riveted on there with some badass industrial rivets.
  • The rear mount is just bolted in..
    I think were making this way to hard on ourselves
  • Hahaha seriously.
    Ok Here is how it goes..
    There is three bolts that hold the rear mount on... One in the back and two in the front..
    The one in the back has the actual mount part in front of it making it hard to get to the rear bolt.. The end.
    I guess yours is different to mine then because my rear mount is two bolts at the front and two badass rivets at the back. :P
    okay im taking pics of this today on the CRX so we can all see what were talking about and ill even attempt stuffing a wrench in there to get it loose but i swear i couldnt do it.....
