obd0 dpfi distributor plug conversion?
I've got an obd1 b18a1 swapped in my wagovan and need some help with wiring. I have a 5 wire dizzy plug on my dx harness, and the colors are the following
Orange/blue
White/blue
Orange
Thin white
Thick white
I have a 7 wire obd1 plug, and I know I have to add 2 extra wires from my ecu but cant seem to find any information on this process, can anyone help me out on this?
Orange/blue
White/blue
Orange
Thin white
Thick white
You'll need to run your wires rom the ecu to the dizzy. ecu C1 pin to blue/green wire and ecu C2 pin to blue/yellow wire on the dizzy.
As for OBD1 I'm not sure but those are the two wires you run for DPFI to MPFI.
if u didnt solder it, and just twisted it together, look there.
if u soldered it, double check your solder connections.
if u re-pinned it, double check the pins arent loose
Depinned orange c1 & moved to b10
Depinned white c2 & moved to b12
Ran c1 to blue/green dizzy wire
Ran c2 to blue/yellow dizzy wire
Matched up the rest aside from the fat white wire (ignitor) which went to the yellow/green wire
Twisted everything at first to make sure it worked, and it did. So then I took the time to solder/heatshrink eveything and it fired up again. Drove it, parked it, now no spark...
Here's some pics if anyone's interested, btw it hasn't been cleaned up in months.
