As the title says, belt is tight, has freon in it but the compressor won't engage. Also the light behind the ac button doesn't work but I assume that's just a bulb. Any thoughts guys? Thanks
Yeah, I checked them all with my meter to make sure, the 2nd fan isn't working either. The ac button takes multiple pushes to make it stay down, I'm going to pop the button out and see if it's making a connection.
Hope this helps.
