D15b2 Swap in rt4wd?
I recently blew the motor up in my 91 rt4wd..
I bought a d15b2 thinking it will work, but ive been reading that you cant? I want to keep RT4WD gearbox, so will this swap work? What modifications are required to make it work?? Im not a SOHC guy, so im lost in the lil single slammers. . Im ripping the stock motor out now, and i dont want to try to make the B2 fit when it Wont..
Thanks!
Thanks!
There are two things that I can think of that need test fitting/verification before saying its a straight swap:
1. Check the bolt pattern of the RT4wd transmission and the b2 block.
2. See if the b2 block is even tapped to take the intermediate shaft required by the rtwd tranny.
3. The cam timing/ignition timing might be a little off but even if, should be workable.
I havent check to see if intermediate shaft will fit because its not here at my house, its at my friends shop..
but hopefully it will all go as planned, and no real probs!
I bought my good friends wagon.. (he posts on here as xxselloutxx)
here's a pic of it..
Still not done yet, stayed up til 5am last night (started at 7pm) trying to get it done. just need to do small things and she should be ready!
I would have checked this first...because if it don't fit, no amount of fiddling is going to make it work.
I don't think you'll be able to use the equal lengths with the d15, don't think there is a provision for the intermediate shaft
might be able to use the unequals swapping the equal lengths inner hubs...maybe
Everything seemed work fine, but on the way home it over heated.. Pulled over, and felt the front hose connected to the radiator, and it was under alot of pressure. what could this be? I took off the water neck, so i can check the thermostat, and that wasnt one in there. lol..
But it took the cap off, it spewed water everywhere, so i let it cool down, filled it up with water again, and then drove it home - which was about 10 mins away.. -- didnt act up at all
But turned the heater on, and it didnt blow hot.. kinda weird. anyone know why?
I drove it today like 5 mins away, it stayed in the middle, then on the way back home it started getting hot. Im guessing its leaking water and making it run hot..
I will look more at it Sunday, i work 6 days a week and never have time to spend on it
But i felt the hoses, and they are pretty tite (being under pressure)
What causes this to happen??
Maybe clogged radiator?
Didnt have any problems til i got off the freeway and started to drive slower (like 30-40mph)
It got hot, turned on the heater and it dropped back down. Ugh, this temp shit is pissing me off
