LS wagovan finally running.
hey i just got a b18a1 and im starting the swap into my wagon...so far ive only unhooked everything pretty much and taken almost all the AC out but on the firewall its a royal pain in the ass to get unscrewed......also about shift linkage which ones should i use and wiring harness since i suck ass at wiring should i use the harness off the wagon or the LS? ill get some pics up tomorrow of everything too
Is your motor stock?
http://www.4gcivic.net/wp/mpfi.html
if you want more technical info about doing a dpfi to mpfi swap, here are some more pages
http://effinmotorworks.com/Effin_MPFI_swap.htm
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
http://www.geocities.com/c_rexboy/mpfi.html
http://www.geocities.com/teampimports/fuelinj.html
basically, you must do the wiring parts described in these write-ups. You cannot swap harnesses, sorry. You'll need to harvest plugs from your mpfi Integra harness, though. You'll also need the resistor box for your injectors and a OBD0 PR-4 ecu for a 90-91 Integra.
All this is assuming that your B18 is from a 90-91 Integra.... if it is from a '92 or later Integra, you've got additional wiring to do and you'll need a different ecu and won't need the resistor box. *EDIT* and maybe some other differences?
by the way here is some pics
The car sits so messed up haha
Engine Bay
Old motor
LS tranny
Various pics of the motor
As you can see its pretty damn dirty and had a bad exhaust leak due to 2 exhaust manifold studs were broke in half. pretty much everything needs to be cleaned up
but anyways, i just got the block back today and hopefully the hed gets here by the end of the week
heres some pics
exhaust side
intake side
other than that, i got the whole block assembled today i am just waiting on the head and tranny
here is some pics
we just re-used the pistons but cleaned them up really good so they look nice
Looks like you are making good progress. 8)
heres the pic......
hopefully i can get a little more money and start buying some more stuff
what you guys think? its not totally finished so dont start talking sh!t
i also put some washers on the back of my hood for that airflow idea and it looks pretty cool so far....
