Weird problem
So, I've got a weird problem with my wagon. Whenever the car is in reverse, the ignition will not shut off and the car keeps running. If I shut off the ignition when in any other gear, the car shuts off normally. Before I go digging into this thing, has anyone here heard of this before? I'm guessing it has to be something related to the backup light circuit since that's the only thing electrically related to this.
Easy enough to see if this is where the problem lies. Unplug the 2 wires on the reverse switch and see if the engine shuts off. If it does, you know that's where the problem lies. You just have to figure out what the actual problem is!
