After everything with the car stalling out and now not being able to start. Ive narrowed it down to the distibutor housing and a bad ground attatched to it.
Considering that I had replaced the coil, ignitor and ect. It figures it would be the housing.
The worst part about it is that the one from my 1.5 that is in my CRX seems to be a slightly larger diameter then the one from the 1.5 Wagon.
so are the dizzy different from 88 89 90 91 like the wiring harness? my dizzy on my 88 went out. same thing it would stall sometimes but then i could get it going and then the other day it just died and i couldn't get it started.
:idea: You may want to read my Si Tip on FREE Ignition Upgrade:
http://www.hondacivicwagon.com/board/vi ... .php?t=739
What's wrong with your dizzy?
pgmfi and dpfi dizzys are different... trust me I found out last night.
