amp installation
i bought some Polk db104 10's from this killer sale at Fry's the day after xmas. each sub was $20...i had to get some. but i have an issue with the amp. where in the firewall would i run the power wire? i know a few of you guys have amps, where did you run it thru?
could you take a pic for me? i dont wanna poke thru a hole that i wasnt supposed to
man i know nothing about car audio :? do i really have to run the RCA cables on the other side of the car as the power cables? to avoid distortion or something? and how should i get the cables to the back? i have a friend that says the poke a hole, then to use metal wire to pull it thru the hole to the back. but then all the experts say to pull back the carpet. which would you prefer?
how much should all the wiring cost? including power, rca, etc (even the connectors, fuse and such)
Wayne
With the bung in the firewall you can just push a screwdriver through the rubber bung and then silicone it up once the wire is through.
high current is going to flow through your power wire, and bleedover can mess with the low current signal in the patch cables.
any other tips i need to know?
oh yeah i was wondering, do any of you have a cut-off switch? so if i didnt want the amp running while the car is on, i can flip it to turn off the amp. is it as simple as just cutting the wire and putting a flip-switch in between?
Hi, I am trying to find the spot to run my power wire for my amp and saw you had posted some pictures, the links to which are now broken. Can you send me some pictures ? I think I found the spot you are talking about, but i cannot for the life of me find where it comes in the cabin. To me it looks like I would have to remove the glove box and a whole bunch of crap just to get to it. Your help would be MUCH appreciated.
Anyone else who has pictures or help from this thread i would appreciate it very much. I just cant seem to find where to run this dang wire! :?
