Important: Oil Filter debate
I've posted this on a couple other boards but its worth repeating.
The debate on what type of filter to use is pretty old...but if you use the OEM filters, you assume its a quality product. Not necessarily.
Take the time to read both articles and form your own conclusions...one is about the large style filter and the other covers the small filters.
See, if you didn't know there were two sizes, you've already learned something.
Oil Filter Article I
Oil Filter Article II
my only thing is why be cheap on an oil filter i mean what is 5 or 10 bucks in the long run ....... we waste that on burgers and fries
There are three large filters - Fram, Filtech and Toyo Roki.
The s2000 filter and HAMP are both made by Toyo-Roki.
The s2000 filter is currently the only large filter still being produced. Although your local dealer may still be working their way through their old stock pile.
Yes, you can run the s2000 filter in our cars.
I ordered a case of the s2000 filters awhile back but now that I've looked at the smaller filters, I would be just as satisfied running the small Filtech-Toyo Roki collaboration. Stay away from the small ones badged as Honeywell.
$13.05 USD based on current conversion rates.
Great...now I need ice for the concussion I got falling out of my chair after reading that.
I was gonna see if it would be worth it for you to pick some up for me but now that I see what you're paying, I feel like I should offer to do that for you.
I can get large s2000 for $6.60-6.90 or the small toyo-roki/filtech for $5.26 (USD). I wonder what shipping would cost.
The part number is H1540-PR3-T01
trust me on this!
In my experience the K&N is the best, oil stayed clear as hell right up to 3k miles. Purolator and Mobile1 have very similar experiences, both have great quality internals. Hamp is also great from what I hear (I have the least experience with these).
In our crew we have some pretty ridiculous cars and all of them run K&N and Mobile1. These cars include a 760whp S2K, 620whp Integra, 560hp 240sx... many more, we all stick with the best quality and usually means most cost but do you really want to take the chance with your motor? I gladely spend $8+ on a filter if it means my high performance car isn't having metal shaving get to the combustion chamber or bearings. I did a write up on my car clubs
website, I'll see if I can copy and add the info here
Completely off-topic, but was this black with a hardtop and ran E85, just traded it for a built white EG on E85 from Utah?
If so, I work down the street from the guy, and bought the 1600cc injectors from that same car for my Starion.
Being in aircraft maintence school, I just finnished a course in engine lubrication. Granted it was relating to airplanes it got me thinking, they put alot of emphisis on the quality of filtration. And for good reasons too. It does a vital role in increasing the life of your engine by filtering out sludge and engine wear contaminates.
I had recently read an artilce somewhere (wish I could find it now) about how Fram filters were junk and should not be used. They stated that OEM filters were a better alternative. They also said NAPA gold filters were up there as far as quality too. After owning 5 Hondas over 15 years. All with over 150k and my CRV at 216,000 now on the clock and doing regular oil changes, I have never had any oil related problems. Or many other mechanical problems for that matter. So, Is Fram junk?? Maybe so, but I am in the belief that if it is, as long as you stay within a scheduled filter change that it doesn't matter.
Just wondering what you guys think, and what kind of filters you run.
I always use HAMP oil filters as I can get them cheap and Ive heard good things. Ive heard both good and bad things about fram, but if they were so bad would it be such a big company?
If they have always worked well for you why change?
I have been using FRAM filters since that is the only ones the Military sells here. Never had any problems but as always I do regular oil changes. On the CR-V and SHuttle I use OEM Honda filters. I got a sweet deal on them (10 for 35 bucks) so when those are done it will be back to FRAM for me.
http://www.ntpog.org/reviews/filters/old_filters.shtml
obviously if the s2000 factory fits, use it.
i change every 3500
oh yeah, i also have a filtermag.
its a semi circle magnet that you pull-off the old filter and install on the new filter and repeat @ every change. check it out.
the oil and tranny drain plugs are also magnetic.
i know its over-kill, but oh well.
wagon...........4ever.....................
Fram Tough Guard(the silver can).
The probs they mention about the Orange Fram filter I don't think are problems.The big complaint are the ends on the filters are made of paper.If you cut open a filter.You'll find there is a lot of glue between the paper & filter.MY thinking is that even if the paper disolved the glue will hold a good seal.
The other prob is they say the pressure by-pass valve sticks open sometimes.I don't believe this is a problem either IF you know what to LOOK for.The following applies to FRAM filter only (maybe other filters).This is from my experience only with regular oil .When you first start the engine .Watch the oil pressure lite.It should go out fast.If the valve is stuck open it takes longer for the oil to prime up.If it takes like a second or 2 before it goes out Change out the filter.This doesn't apply to Purolator filters.
THe following are what I hear are
GOOD Filters:
Wix
Purolator
Fram Tough Guardonly(NOT Extra Guard or Double Guard).
Baldwin(Biggest filter company.They make filters for lots of companies.Maybe more costly.)
OEM or Hamp (both cost more.It's always safe to use OEM filters if you're not sure.)
Check above ragenasian's link to who the above filter companies also make filters for.
______________________________________________________________________
My Observation:Sounds crazy ,but you may want to consider Stop Tech(A WalMart brand).Good price point & quality.The Bosch I cut up is probably made by Champion Labs(they make filter for a lotta companies) which probably made the StopTech too.The StopTech filter looked like the Bosch,same by-pass valve,same construction filter,BUT larger & cheaper.
Air-cooled Volkswagens had no filter, just a screen to catch the big chunks and a very effective (oil bath) air cleaner. They ran at much higher oil temps than our water-cooled wonders and the recommended oil change interval was 3000 miles. If you're changing your oil every 3000, it probably makes no difference what filter you use. However, if you are stretching that interval or running with an old air filter (or without one at all), then you might want a high grade oil filter.
