RT4wd sedan
Basiclly a buddy of mine has a 91 4door dx sedan and is set on swapping over the RT drivetrain for a little extra handling and original gangsterness. It was an auto but the 5sp was just recently completed. Offical measurements haven't been taken quite yet but we know the axles will for sure need to be enlongated. Considering the narrowness of the wagons vs. the sedans. He obviously has much more ef community knowledge than I on how to get this job done and what to plan for during this build. However, I am curious of all your input and suggestions as ill be part time co-builder. I personally haven't spent a ton of time under an RT4 or sedan so I guess my first question would be.. Is there enough space under a sedan to run the driveshaft or would we have to create a "valley" in the floor to tuck it up? Also does anyone know if the tranny/transfer case would clear the firewall in that area? Guessing some serious rearrangement will be needed down there. Hopefully I can bridge the knowledge gap between yall and him to create this RT4wsedan! Thanks for time!
-Engine, gearbox, transfer case, axles etc will all go straight in if you use all wagon stuff
-You will have to fab up the rear end as a wagon rear subframe bolts in but a sedan rear subframe is part of the chassis
Honda made a EF RT4WD sedan, there is an australian member on here with one
If you want more info search trailer park rally car.
Awesome this will be a huge help! Were in process of lookin for a doner RT for the conversion to go a bit smoother. Do you know by chance what the aussi members profile is? That blows my mind haha never heard of it
... Thats also a really clever idea we'll consider! If we can find a decent doner RT than it seems like the route to go if we need that little extra clearance. Thanks man we'll have to check out trailer park rally forums. haha sounds like one of my new favorite sites
tprc is not a forum its what he called the car. The forum the build thread was on went to sh*t, I don't care to mention the name.
http://www.honda-tech.com/showthread.ph ... pic+tuning
