There are plenty of guys here running 15x8 zero offsets but it will stick out a bit. If you aren't into much fender work I think anything with a 15 offset and higher would be best. Search around a bit through the mini gallery or the wagon of the month archives and you will see numerous wheel dimensions to work with.
Also any offset will fit, just depends on the amount of fender work you want to put into the car aswell.
