Offset advice need
What offset (range) should fit for a EF wagon? I am looking to put 15x8, 205 tires
  • most inexpensive wheels are going to be 0 offset @ that size.
  • jt223539jt223539 New Wagonist
    I think some other sportmaxxs come in 15x8 +20.
    Also any offset will fit, just depends on the amount of fender work you want to put into the car aswell.
  • There are plenty of guys here running 15x8 zero offsets but it will stick out a bit. If you aren't into much fender work I think anything with a 15 offset and higher would be best. Search around a bit through the mini gallery or the wagon of the month archives and you will see numerous wheel dimensions to work with.
  • NZ-DB8RNZ-DB8R Moderator
    I have 15x8" +35et with 195 tyres on the front of my wagon and to me, they sit perfect. Dont stick out at all
