+++ SiWagon Freebie:Honda Ignition Upgrade:D
There is a FREE Ignition Upgrade from Honda.If u go into ur nearest Honda Dealer or call them.They'll tell u if ur Civic Wagon has been upgraded or not.You can also call their TOLL_FREE # 1-800-999-1009.
They replace the ignition Ignitor in the Distributor .FREE labor too.At my dealer there was FREE Internet & pastries too.:o Now that ROCKS!You leave ur wgn there for 1/2 a day.Covers '88-'91(USDM) & maybe '92-'96 in other countries(not positive.).:D
:arrow:Some of the Signs of a BAD :evil: Ignitor .
1)You may get a early warning.The engine will die all of the sudden.Overtime it'll happen more frequently.
2)A lot of times it'll restart after 1-3 minutes till it finally DIES:
3)You'll be going along & the engine just cuts out.Cranks,but NO start.Can't roll start it.
4)A Code 15 may show on the ECU "Eye"(LED).
5)It'll enter a limp home mode.You'll be lucky to get 25MPH if u time the lites & roll the STOP signs.
I've "read" some accounts of other 88-91 owners that have been turned away because the recalls have expired, or some such.
On the recall, it replaces a specific part that has been known to fail. Which is why you were able to get the igniter replaced despite the car being fifteen years outside of the engines warranty. Even still, some people are saying the "recalls" may or may not be honored these days.
My CDM Civic driver side belt has started to fray. Is this what the "lifetime" warrenty covers? Even if Im the second owner?
I will post back with an update.
Although they did mention a difference in the 6 or 8 pin. Got me ? Maybe a harness difference or the 1.5-1.6 or something?
Also, seat belts ... They told me they only keep stock up to 15 years and so what ever they have is what they have. If the colors dont match at least you will have a function seat belt.
NO.It's for '88-91 Civics & Accords.Check with the Honda website or Dealer.Seat belt applies to all Honda's.
I have a 91 Civic Wagon 2WD 1.5 liter.
So..."life time" warranty actually means "until we run out of parts".
Thats what I was told by EJ Josphson the Lead Custumer Service Tech of the North American Honda Division.
They told me he was one of the best known Honda Guru's !! That guy was full of usefull knowledge.
As for seat belt I donno!
Cheers!
as far as the ignition upgrade goes, i dont have a punch on my firewall... better check that too.. even though my local Honda dealer is a mother fooker when it comes to service :x
thats f**ked up big time. yet again why i hate my local Honda service place
they said they would fix the seatbelts IF it was an electrical problem.
if it was mechanical, they would not.
they also wanted my car for 1 day just to look at it.
has anyone disabled the autobelt's "beeping?"
my autobelt is broken and loose, so it "beeps" a lot.
Yes you can disconnect the beeper.Every Civic I 've had I disconnect it.It's SOo annoying.
i fixed my autobelts with a couple of inline fuses. the fuse box that was on the positive battery terminal on my wagon was all corroded and broken. couldn't find that box anywhere, so I cut the clip off the wires, that plugged into the box, and spliced in inline fuses and attached them to the terminal... works perfect, no beeping and the belts move properly.
