i dont know where this should go but my key ALWAYS gets stuck in the ignition. i heard it was because of some weird saftey thing. i would like to know how to get it un stuck thanks
i just ordered the part to fix this today. If you have an automatic then this is happening because of the shift indicator switch. does the P light up as soon as you put it in park?
you could probably install a switch that you could manually switch yourself..
