Yes, those bars. Are you sure I need wagovan panels? Anyone know the measurement from bottom of window to bar? Maybe I can mock this up and make it work on my RT4WD panels.
I'll reply only for the fact that the answer hasn't been covered yet...
The RT4wd models don't have the holes/squares punched in the body for them to be
mounted. Furthermore, the plastics would need to be drilled out (I'd just get wagovan
ones precut)...
I tried on my 91 and now have a hole on both sides and no cargo bars. There's no holes
on the body of either of my 89 RT's either...
If you really took your time you could mount them, but I just gave up. Too much work for
something I'd probably rarely use...
Can the come off some other car? like a DA?
And how do you put them on?
viewtopic.php?f=16&t=3322&hilit=jail
Hope it helps
Tryin to upload other pics but its not workin
ones precut)...
