88 wagovan runs great cold, doesn't run after warm up.
Hello, hoping someone can help with a diagnosis problem.
I have an '88 wagovan that is running great when it is cold, but as soon as the engine warms up, it coughs, sputters, misses, dies.
there is a loud (ish) ticking sound near the throttle body, and it sounds as if there is air being sucked in somewhere. could this be a vacuum leak problem, or maybe a manifold gasket problem? how do I check that without taking the thing apart and replacing those gaskets.
any help is greatly appreciated.
one other thing to note: this car was running perfectly when I took it off the road around thanksgiving due to a bad cv joint in the front. I fired it up yesterday to drive it into town to have that cv joint replaced, and thats when it let me down. also its worth mentioning that it has been about 14f out here for the last couple of weeks.
thanks
thanks
The vacuum leak could have materialized as a result of the cold temperatures. The extreme cold causes the metal to shift/expand/contract, and if a particular gasket was on it's last legs, this shifting could have caused it to fail. The cold makes the metal contract, then you run the engine making the metal expand. That might have been just enough stress on that weak gasket to cause it to fail.
