Compatible parts?
would a left rear control arm be the same as a rear left trailing arm, froma 1990 honda civic dx? please dont delete thisi friken looked..didnt find..im deep in hole..hit a curb and bent my rear left wheel..so please just answer...
Just a tip: Having seen this happen before, I wonder if your problem isn't a bent rear crossmember. Look where the lower control arm bolts to the crossmember.
If it's a trailing arm that you need, then it HAS to be from a Wagon, and it has to be either from a FWD Wagon if yours is FWD, or from an RT4WD if yours is 4WD. However, if what you need is in fact a lower control arm (LCA) then you can use one from a Civic hatch, CRX or sedan. If your Wagon is a 1988, you need a 1988 control arm. However if you wagon is a 1989 or newer, then you can use an arm from any 1989-1995 Civic or 1990-2001 Integra.
As Bam already mentioned though, if your LCA is bent, then the rear crossmember is probably bent as well.
