Auto to Manual conversion help?
Hey guys,
Was wondering what I need for an auto to manual conversion? I'm planning to get a motor with a box on it so don't need the box.
Will any pedal box from any car work or must be off a EF/DA/EE?
I'm guessing same mounts and everything as this is a 56i (is that what you call for fuel injected wagons)?
Thanks in advance
Thanks in advance
get ready to be told to search
So, to answer your question about what you need:
Transmission
shifter
shift linkage
floor/tunnel section if you wish to seal it up and use stock boots
clutch cable
pedal assembly
manual ECU
manual instrument cluster
The mechanical part is fairly straightforward. Electrics will depend on what year your auto is, i.e. whether it has shift interlock etc. On the '88 I just had to jumper 2 wires to defeat the neutral safety switch. (If you're really picky, use this same circuit to wire clutch safety switch).
The only other thing that comes to mind is that the auto. engine harness doesn't have 2 wires for the reverse light switch. If you care, you'll have to extend the green wire from the plug under the (auto) shifter.
Depending on year of your car, if its 26 spline they are all the same auto and std, And also if your AWD or 2WD.
If 2WD you should be good.
What are you talking about? :shock:
There is about an inch and 3/4 difference in height... The manual 4wd is higher
No, match only RT4WD mount. it's quite special.
Here you are my photo from my build what is difference between auto vs manual RT4WD bracket:
Drilled out mount of automatic gear box, and welded in bracket from manual RT4WD gear box.
The difference between automatic and manual gear box. (red one are from automatic).
Are you sure? It was just explained above that the mounts are different. This might confuse some people. Can you clarify? Have others been wrong in the past?
Are you sure? I bought a parts manual RT4WD. The owner before me changed a auto RT4WD to a manual using this parts car. He took the trans mount.
Mark.
They are different, the manual mount is about 1.75" higher than a auto, I just cut the auto one off mine and welded to manual bracket to finish my swap..
a)manual AWD?
b)manual 2WD?
I have an 88 trans, and a 91 body. My rear mount doesn't seem to be lining up. Wondering if this is an auto-manual issue, or an 88-89/90-91 issue. Any thoughts would be helpful!
I didn't take that bracket off the car...it's crushed at this point. FAAAAAAK.
Can you get a new one? I would imagine the old one was junk anyway. I was surprised how many of these parts are NLA when looking for parts for my recent manual swap. My donor car was an 88 and I had no idea how different those first model year cars are. You might need to fab something up.
Yeah, I think were gonna weld up the holes and drill new ones. Faster than searching for an 88 probably.
