Spedometer and gauge lights quit working
I recently bought an 1988 Civic Wagon and on the way back on the 200 mile trip the speedometer and gauge cluster lights quit working.
What might have cause both the speedometer and the gauge cluster lights to quick working at the same time. I took the cluster cover off this afternoon to check to make sure the cable was secure in the back of the cluster and it was. I also looked at the fuse box under the dash and checked which fuse would have gone to the cluster and it wasn't blown.
Could the light bulb for the cluster have blown out and also could the cable have gone bad? I'm also getting the ECU code 17 which I know is from the speedometer not working
I pulled the cable from the tranny and turned it a little and it felt pretty loose, I gave it a little tug and it just came out. I guess it broke off about in inch and a half up so I'll have to replace the cable.
I have another gauge cluster that I put in the wagon and the cluster lights still didnt work. The lights like high beam, turn signals, brake etc all work but just the main lights arent working.
Is there another fuse I should check out that would cause this?
the indicator lights are on a different circut from the illumination ones.
if the tail lights work, check for bad connections to the cluster and the dash grounds.
if the tail lights don't work, check for power at the fuse (both sides) with a test light. if you've got power on one side but not the other, change the fuse. if you don't have power on either side, just keep going back through the circut until you find the break...
could be a bad fuse box - i've got that circut bypassed with an inline fuse on mine, because the guts of the fuse box are slagged.
here's a link to some service manual downloads that may help:
http://spoonhonda.com/downloads.htm
The tailights work fine so I'm going to assume that it's a bad ground somewhere.
I have a Honda service manual for the 89 Civic and 91 CRX, would those be simliar to the wagon and where can I find a Honda service manual for the wagon? I saw one on eBay a couple of weeks ago but they wanted over $70 for it.
Check dash fuse # 8(10a).See if the connector came loose on the dash dimmer.
Be patient I've seen shop manuals go for around $20 on Ebay.
Good Luck
I was messing around with the dimmer switch and the lights magically came back on, I guess the switch was just a little loose.
The inner parts of the speedometer cable broke so I ordered just the inner part from www.hondapartsdeals.com. Is there anything special about replacing the inner part besides just pulling it out and putting the new one in?
When you go to reinstall could you possibly take pictures of give instructions as to which way you routed the cable when you put it back in? Cheers.
Well Hondapartsdeals emailed and said that the part was on back order with no ETA so I canceled it. I then went to www.slhondaparts.com and ordered the same part. The order was stuck at "Pending Credit Authorization" from 11/21/2006 till 12/06/2006 and I checked it today and it says "Shipped on 12/7/2006". I never thought it would ship or get my speedometer back.
About the installation, what kind of lubricant should I use when I putting the inner cable in? I will also try and take some pics and do a write up.
