What radiator fits 89-91 shuttle
as topic says. is there any other radiators that fits this car? search and found that integra DA fits. any others?
    Any other '88-'91 civic will also fit.
  • You can put half sizes in there with modifications but don't know why you would want anything other than a regular 88-91 civic radiator unless you need the space for something.
  • dunndunndunndunn Band Wagon
    isnt the 88-91 civic (not shuttle) smaller?
  • There are a couple sizes of 88-91 radiators, but for all intents and purposes they are full width. The one that was in my 89 hatch STD was about 4" narrower than the ones that come in the Si. None of them OEM style EF rads are 1/2 width though.
  • DA Integra is a Dual Core, where as the Civics (Wagons included) are a Single Core.
  • the mishimoto crx rad will fit with alittle bit of modification and work.
    but everything is alittle too close for comfort imo :?
  • Just use a 92-95 civic alum rad.. U just have to have someone move the bottom support and you will have a ton more room for that PT6262 to sit up front haha Its pretty simple if you can drill and weld and I think you use the 92-95 civic rad hose (I think)
