automatic trans slips
i have a 1990 2wd automatic and when i come to a complete stop and the car is completly warm some times when i start off the transmission slips i was wonder if there is anything i can do to stop that or is the transmission gone i checked the fliud and it is full
1)Honda uses a odder oil level check procedure.a)On level ground.
b)Within 1 minute of turning off the engine(I don't know if they
want the tranny warmed up or not.Check your owner's manual).
c) pull dipstik,clean,reinsert fully & pull it out to check level.
TIP:Never over or under fill a AT tranny.This can cause it to slip.
