i checked all the fuses in the underhood box and they are all good. the stereo has been in the car since i bought it. im gunna go out and check that underdash fuse and see if its okay. the charge light has never turned on not even a flicker.
well problem is all fixed it was the alternator. im thinking the reason it slowly died and didnt trigger a charge light is because it was barely working.... iono its fixed now.
I'd start by disconnecting your headdeck for the period it normally takes to go flat.
#31(60a) & #32(50a) in Main Fuse box(the one that looks like this,"[":Probably OK.
#14 in the Dash fuse box.
Probably not the fuses.Has Alt.lite come on?
Or like Pacifier said recently upgrade or put in a new stereo :?:
