Help! I'm leaking coolant!
I recently lowered my wagon and it seems like I hit a problem. So any help would be greatful!
I drove to work yesterday, roughly around 30-40 miles, and when I got there I noticed I was leaking a huge amount of coolant because of the green color. So after work, I refilled my radiator with coolant...my resevior was still in tact and it was still filled. I drove to my friend's house about 40-50 miles and once I got there I noticed I was leaking coolant again! On the drive there, however, my temp. gauge did not rise nor stay in the cold zone. I decided not to refill it for the drive back to my house, which was about 5-10 mins away. Once I got to my house, I wasn't leaking any coolant, and the temp. gauge did not flare up to the heat zone or anything either. So, I have no idea what is wrong with my wagon! Is it the water pump, a loose hose, or the radiator itself??? I wouldn't know how to check it myself either. I am going to take it in the shop on Wednesday, so any response would be helpful, because I don't want the shop to rip me off. Till then, I think I shall keep adding coolant...someone please respond or PM some advice!
I just put a full omni coilover suspension with full camber kits, and it is sitting on some fresh Mugen NR's so help me keep this wagon sexy by running cherry!
Thanks!! I'll try your advice right now
You can't expect us to give you detailed instructions on your car, without detailed information.
There's only so many places coolant can leak from. Go outside, and watch for the leak. Then fix it.
How are we supposed to know if it's your water pump, or your radiator, or a hose?
If you're capable of lowering your car.... you're capable of fixing a coolant leak.
Even if you don't do it yourself, at least you'll have an idea of where the coolant is coming from.
Even though I'm going through some problems, I'm kinda glad I'm learning a lot about my wagon. I've never really been good at engine repair and all that good stuff. And slamming the wagon was a very cool learning process as well...I'm going to put up some pics soon of all the work coming along. I noticed a lot of people in this forum seem verrrrrry mechanic savvy...I wish I knew half of what everyone on here knows haha
Do yourself a favor before you take it to a mechanic, crawl under it and look for fresh scrapes on the crossmember and the oilpan, if theres some on the crossmember then proceed to check the bottom of your radiator for cracks, good luck bud
Find that leak!!
