oil pan removal in my RT t-case is in the way
well im changing my clutch as we speak and as i was under it i noticed that the t-case is in the way of the oil pan. the only reason this concerns me is that in a few weeks i will be putting the turbo on my car and i planned on removing the oil pan to tap for an oil return line and of course change my pan gasket as well. i noticed a few 14mm bolts holding the t-case to the tranny i took a few off and thought to myself that i should prolly ask before i tottaly unbolt it just in case. i guess what im trying to ask is can i simply un-bolt it and slide it out? if so i see no way that im gunna be able to take my pan off if i put my tranny back on. thanx
heres the pic of my tranny
before
bling bling
resufaced the flywheel at work today
and of course the clutch kit
In case the delay had prevented you from getting to it yet. It's safe.
do tell what degreaser you're using.... never have i had anything powerwashed/degreased and bling that well...
and since it was up in the air i got the 10an male bung on its way so i can pull the pan weld it on and throw it all back together. purchased my new mani and turbo last night as soon as they show up ill post some pix of it but i think ive got this clutch and oil pan prob all figured out
FYI, if the transfer case gears are not put back properly & checked for lash ect. then it will start eating itself. In the Helms manual its states you are supposed to rotate the assembly once reinstalled & use prussian blue to check the gear contact, Honda has part numbers available for different thickness shims to correct the differences involved in the re-installation porcess. Please be careful as the transfer case is a vital component in the rt system.
Helms is a lifesaver!
@turbo_teg: when you cleaned the tranny, what did you use to prevent water from getting into the transmission case where the axles go?
