1990 1.5L EE wagon wants to stall when the brake pedal
When I put the brakes on to stop or slow down, the engine wants to stall. As soon as I lift off the brake pedal, the engine is perfectly OK.
The previous owner possibly had a security system on it and installed hydraulics as well.
What I am left with is a bunch of wires in the right front fender wheel well.
The car runs great until you touch the brake pedal.
My mechanic needs multiple suggestions to try to find a solution.
GOOD LUCK!
And as a second thought, check your battery and alternator. If they are not supplying enough power to the car when you draw just that little extra to light up the brake lights the car will also feel like it is going to stall out.
Let us know what happens.
