toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Engine & Drivetrain
Why the coolant fan keep on>?
raymond20035
Band Wagon
October 2010
in
Engine & Drivetrain
I changed my coolant yesterday and somehow the coolant fan just turn on why?
NZ-DB8R
Moderator
October 2010
Did you bleed the new coolant in? Could be a an airlock around the fan switch
knowcones
Band Wagon
October 2010
If the coolant temp sensor is bad, the fan will stay on- might want to check connections and if they are good- replace the sensor.
Sign In
or
Register
to comment.
