having some troubles on my obd1 conversion
okay guys tonight i went to put my obd1 dizzy in and its not working. first off i noticed the mounts were totally different so to correct for this i set the motor at TDC then pointed the rotor to the plug wire going to cylinder number 1. it fired maybe 3-4 times but never actually started and never even fired off again. im not new to working on hondas but i have to admit ive never realy delt with d-series motors ive always had B's but im always game for learning more.
heres the dizzys
heres the obd0-obd1 conversion harness
and one more question WTF is this thing mounted next to my map sensor? can i just get rid of it by unhooking it and plugging off the vacume lines hooked to it?
heres the dizzys
You have a vacuum setup that i've never seen before but that may just be because i've never actually physically worked on a USDM motor. Usually there is two hoses there, one for the MAP sensor and one for the charcoal canister.
You're 100% sure you got the timing right?
