A Spring questions.
Alright, I'm getting ready to drop the Wagon and I have some questions.
What kinda drop are you guys running? (1", 2," 3", etc.)
What are good shocks and springs?
(I'm new to car suspension so I'm not sure about all these springs floating around)
I found a set of Sprint Extreme Lowering springs on Ebay, and they drop the car 3.25" in the front and 3.0" in the back. Is this too much for a Wagon with 16" rims and 205 tires?
Are Sprint springs any good?
http://www.sprintspring.com/springs.html
Has anyone had to have their alignment re-done after a drop?
Should I get aftermarket shocks, or are the stock ones ok? (besides the rear, I know that part)
I think that is about it. Thanks
i would say get new shocks. even with a slight drop, you're probably gonna blow out the stock ones after so many bumps and holes. remember, those things are about 16 years old now.
i havent had alignment done. there wasnt much of a problem with that. but you might want to adjust the camber a bit too. either with the 'washer method' or just getting a kit to adjust it. with any sort of drop, your tire wear will suffer....so if you're not into changing tires every 6 months, look into your camber.
$200 won't get you a spare tire.
quit dreamin'.
putting your ride together right costs grip, if you're not willing to shell out for some basic necessities, then forget it.
suspension equipment is the one of the most costly on any car.
was that on this thread? hahah i dont see that anywhere
