So i've searched and need clarification
I keep looking at suspension set ups for the wagon (when I get one I plan on dropping it pretty dang low).
If I get a 91 wagon is it true that i can get 88-91 civic coilovers and they will fit?
Like this set up here : http://www.weaksauceparts.com/store/pro ... 170&page=1
Then buy the pair of top hats for the front, the back is not necessary correct?
Also if I get coilover and LCA's I can get these blox 85-95 civic ones right: http://www.weaksauceparts.com/store/pro ... 082&page=1
Then I read stuff about toe set ups to fix camber? Is this another thing necessary to get?
Sorry if this already has been covered but like I said I just need quick clarification cause I keep reading stuff about EF suspension and DA and I think I get it then I get confused again.
Thanks in advance.
Thanks in advance.
-If you get aftermarket LCA then any rear shocks with a Fork type attachment will fit (EF, EG, DC, EK etc etc)
-I personally would recommend getting extended tophats for the rear, better ride quality and more chance if keeping rear springs captive which in my opinion is a must
-I would also say that if you are going to be slammed then definitely invest in some adjustable Toe and Camber arms, it will save you having to buy tyres every second month
So those Ground control coilovers + Koni Yellows + Ground control top hats will work with the blox style LCA on a 90 or 91 wagon as long as they are for a 89-91 civic correct?
If I read your reply right anyway lol.
viewtopic.php?f=8&t=10271
Beware! EK is not a bolt on. It can be made to fit, but it takes some fiddling.
Yeah I read this and thats why I asked if I needed the toe adjusters which seems like thats a postive yes
as long as I want to keep my tires for more than a month lol.
So then I can use this suspension as long as I get read aftermarket control arms according to what "NZ-DB8R" wrote.
And then they'll have no problems fitting in the front as well correct?
and to get another confusing thing out of the way, do I buy stuff for an 88-91 civics or crx's? I see both on some posts.
yeah i believe the rear is eye type and front is fork type. I just don't want to spend 1k on suspension and then not have it fit on either haha.
thanks for helping guys. Are sway bars the same, aftermarket, buy for 88-91 civic?
yes I heard and read they do and the fabrication is where it threw me off. So what about under the wago? I know certain OEM ones fit but what about aftermarket? same as the fronts? and the one in the rear that needs fab work is the one inside the trunk correct? or even underneath? I think I read something about someone having to fab the lower rear one as well.
Thanks for everyones help! newb to the wagoscene lol.
Just to clarify: 1988 wagons have the "eye" type rear struts/lower control arms. '89-91 (and all the aftermarket ones I've seen) are "fork" type.
Note the year and differences between 88 and 91. Same changes happened to crx as did wagon...
