First thing you do after buying a wagon?
I just bought a 91 rt4wd wagon and was wondering what you guys check and do right after you get them.
I was thing oil change for sure but should I mess with the tranny or rear dif?
I do get a weird vibrating noise from under the car when driving and some times at idle. The guy said it was a loose heat shield but could it be something else? I can't find anything loose.
check valve lash. check hoses for leaks
thats all i can think of right now.
i used techron twice in the beginning one for every fillup, then once a month.
your best bet is to seafoam your system.
my 2cents.
the noise could be the heat shield along the exhaust between the cat and the rear axel.
Sea foam? Does it help much?
valve lash adjustment video- http://www.youtube.com/watch?v=uqMYMskOQQQ
Is that what you guys do also for seafoaming the car
I've never heard of all 3 of those steps I've just heard of the hose one
the mechanic also used gas and water combination to clean like the old days. he said a bucket of water w25% gas.
the gas contains paraffin which acts like a wax, but better. his cvcc was clean and engine was strong. so believed him.
i haven't tried the gas water mix to clean the car.
Yeah, I know. I'm not against it. I just have never tried it.
first thing i do when i buy a car
Clean it
inspect it see whats good, what needs to be replaced,
then tune up- cap, rotor, plugs, fluids
take everything out and vacuum it all out
throw on a spare set of wheels kicking around the garage
top off fluids
fill with gas and see far you can go on a single tank
Remove entire interior
Wash like hell
clean years of ooozzz off the floor while carpet is out
let dry overnight
reinstall and enjoy your fresh smelling interior
2. Change engine/tranny oil/fluid
3. Paint trim/bumpers black
I just bought our wagon a few days ago and I noticed the black trim seems to have faded.
Agreed. Slam it on it's nuts. Probably one of the best things to make your wagon look better.
Agreed.
And then take 50 pics of it (all at strange angles) and post up here.
I got a notebook and wrote down all the information I could about the car, then labeled four separate pages as: Exterior, Interior, Mechanical, & Electrical where I listed all the problems with the car. Another page I labeled Modifications where I wrote down significant changes, not just repairs, that I'd like to make.
Then I got to work!
