Will these A/T tires fit?
Hey guys... new guy here. I have some Non-Traditional plans for my RT Civic. I have done a ton of searching and reading before I decided to post this question. It seems the majority of RT Civic owners want to lower their ride, but I am wanting to go a different route. I am planning on lifting mine and adding All Terrain Tires. I have the tires picked out, but question if they will fit and am hoping you guys can help before I lay down $600 for tires to only find out they wont fit.
General Grabber AT2's
215/65/16
My research shows they are 27" tall compared to stock tires having a height of 22.7". So, I am looking at an increase in overall diameter of 4.3". I realize it will jack with my speedo and crap, but it seems doable. I almost wanna say I could do it without lifting it any, but a coilover package couldn't hurt if I raised it an additional inch or two.
Anyone have any thoughts besides that I am crazy?
215/65/16
I thought there may have been a thread titled "will these tires fit" or some such with a detailed discussion of the issue.
Your ride is an '87? Not sure how a lift might be accomplished on a torsion bar setup.
turning will be an issue, the inner side of tire would rub when you turn. there are other sizes.
my2cents.
guy n Pennsylvania is runnin 22inch rims on his wagon....
if possible run to your local used tire seller and get a tire of the same size mounted & do a few test fits....
i was planning on running a 27x9.5x14inch SUPER SWAMPER ...
but i did a Big Brake upgrade and now i cant fit a 14inch rim over the brakes .. so i picked up some mini cooper rims .. but i have an 88 rt4wd and im installing suspension components to lift mine and or a member here made some lift equipment ... http://www.hondacivicwagon.com/bb/viewtopic.php?f=8&t=8610&start=0
It's not that I want that particular A/T tire and size, but rather that is the smallest A/T tire I have been able to find in the height department. If someone knows of an A/T tire make and model that is smaller then by all means let me in on it!!! I just want a minimum of 15" Rim.
Thanks for the info fellas!!
They have two tires that might work the MT-753 bravo Available in a 185R14C which measures 25.5x7.40
And the bighorn and buckshot mudder can both be had in a 27X8.50R14
which according to maxxis measures 26.3x8.8
I dunno where or how much it would cost to actually buy a set though...
when i buy tires i look for a specific tread for my wild needs... and they only cost me $73 each mounted and balanced ..
