1991 2WD Wagovan Cranks but won't Roll Over. [VIDEO]
Not sure what is wrong here, I just replaced the main relay and charged the battery. Below is a video of how it sounds, I'm hoping someone can draw a conclusion from that.
Also, I think I can hear the main relay click and the fuel pump buzz, but I am fairly vehicular-ly retarded. Lemme know if you need any more details. Thanks.
http://www.youtube.com/watch?v=QGFT7ym8Pjs
A. The spark is good.
B. The engine still doesn't turn over when manually adding fuel.
C. The battery isn't the problem.
D. The engine may be blown.
Can someone that knows quite a bit about hondas give their opinion based on what I have provided?
I'm just an amateur though.
Seems like a fair enough assumption, I looked up a guide on how to do it on a Accord, seems fairly simple and backwards compatible. My only issue is, where do I go about getting a compression tester? Is it likely I could find a shop to do this for free?
I'll ask around my more mechanically oriented friends and see what I can find.
I am running up to the hardware today to grab some sandpaper to try and clean it up a little bit, I don't expect it to help that much but it's worth a shot.
Engine Cranks but will not start:
1. Fuel Tank Empty.
2. Battery discharged (engine cranks slowly).
3. Battery terminal connections loose or corroded.
4. Leaking fuel injector(s), faulty carburetor, fuel pump, pressure regulator, etc.
5. Fuel not reaching fuel rail or carburetor.
6. Ignition components damp or damaged.
7. Worn, faulty or incorrectly gapped spark plugs.
8. Broken, loose or disconnected wiring in the starting circuit.
9. Loose distributor is changing ignition timing.
10. Broken, loose or disconnected wires at the ignition coil or faulty coil.
I do not, I suppose I'll start on that list. Gives me something to do for the day :P
Also, to ensure that it's not the Main Fuel Relay...
My plan for the weekend,
First, test the wagon with another distributor, just to make sure this isn't my issue.
Second, make sure the timing belt is where it's supposed to be.
If both of that fails, I'll probably just spend the rest of the weekend crying or swinging a hammer at the wagon.
If you have a dizzy to compare it to, then you can do this same test for all sensors in the dizzy. Ive only tested the ignitor before so cant tell you what result to expect
