Squeeky bed spring sound
Lately i have been having a loud squeeking bed spring sound comming from the left front suspension.. It used to only seem to do it when it rains, but lately it does it when i hit bumps, turn, or when i just sit idle and turn the wheels. Seems to be getting louder and happening more often.. Any ideas ? Thanks
    more info bro...
    what suspension you using? stock, coilovers, etc...
  • MotionMotion New Wagonist
    91 rt with stock suspension.
    all i can think of is that the rubber deteriorated somehow.
    have you taken a look under there yet?
  • My wife's accord did the exact same thing. It kept squeeking, and we couldn't figure it out. I finally traced it to the lower ball joint, so I filled it up with some grease and the noise stopped. It came back maybe a week and a half later, then shortly after, this happened:
    I would start by checking your ball joints, and if you find out that is what you are hearing, FIX IT!!! You don't want it to happen to you.
