door hinge problems
is this a problem? cant I just remove this part? what does it do anyway? isnt it there just to stop my door from opening out too far?
Driverside
here is when I open the door. it pulls out.
and if i close the door a little it goes back in place. see the crappy welding?
Passengerside
this one works fine.
Driverside
Passengerside
What Jaker's saying is that " There's no physical way to access it without cutting the door jamb area open." !
I have seen three categories of driver door check straps:
Original, unbroken ones
broken ones
repaired and REbroken ones.
I'm not sure what lies inside that a-pillar, but it must exert more leverage than a weld at the face of the jamb can handle.
I just went through the whole body section of the Helms, and there is no mention anywhere of that piece inside the A pillar. If you were hell bent on doing it OEM, you'd need to steal that section of A pillar from another unibody at the wreckers, and cut open your A pillar to slide it inside, and then weld the whole works back together. Not worth my time and effort, not to mention the possible repercusions to the structural integrity of the unibody in that area.
Right now mine is 'clicking' really bad. Not fully broken, but annoying...
It seems to be a fault I've only ever seen on Shuttles.
Both the ones I had and Marc's have the same problem, but of course on the other door
I didn't mean to imply that you couldn't do it, I've seen your work and am impressed.
I'll have to cut into one sometime to see what's in there. It just feels like there's more leverage exerted than a weld that close to the pivot can hold.
I used a stainless steel plate item # SH-0200 from here:
http://www.mmsacc-stainless.com/html/tubing.htm" onclick="window.open(this.href);return false;
I cut and bent the ss plate to fit and used two 1/4" size rivets to mount it.
works great now..no noise, it moves just a tiny bit but I wedged 2 stainless steel screws in there to prevent that.
while I was at it I ordered stainless steel 6mm flanged bolts to replace everyone under the hood.
http://www.mmsacc-stainless.com/metric/ ... c_hex.html" onclick="window.open(this.href);return false;
I never thought of adding a piece to fix it.
I like the rivets.
if you made the stainless more of a wedge shape you could put 2 rivets top and bottom to avoid the movement.
You have inspired me to use the metal breaks at my old mans hvac shop to fix mine.
Thanks for posting that.
it was difficult drilling the rivet holes through the plate so I only made the 2 required holes to mount it with. perhaps I can still drill a hole and add another rivet to the bottom part as there is room for it. it just may be enough to prevent any movement without the screws.
thx for the tip!
ps I only wanted stainless steel to avoid any rust issues in the future. after scouring the web this plate was the best that I could come up with at a reasonable price and so had to work with it. I'm satisfied with the end result and it even looks somewhat of a clean fix!
they hold the doors open and stop them swinging shut
it happens when you door is used excesively, or the door is pushed opened too far, too many times.
i may get mine just spot welded back on. they are welded to the inside skin
I added another 1/4" rivet to the bottom piece and that was enough to stop the whole thing from moving completely!
it is rock solid now.
note that the bottom piece is mounted a bit crooked leaning to the right. that's on purpose to push the pin further to the right(towards inside of the car) restricting it's movement. I'm very pleased with it. I also dabbed a little silver por-15 on the surface rust that formed where I previously had the ss screws.
good fix though 8)
10x more solid than the factory setup and no need to do anything else. You can even make it pretty before you paint so it doesn't make your eye squint every time you look at it.
