Difference between 92-95 and 99-00 d15b
whats the difference between the 2 d15b's?
i know one 92-95=ODB1 the other is and 99-00= ODB2
im gonna be picking this motor up tomarrow any info would be great.
here are the links to the 2 im talking about.
92-95 d15b
99-00 d15b
how do i tell the difference between the 2?
92-95 d15b
99-00 d15b
There are more than one version of "d15b" per obd generation. There was a z6 equivalent (except that it's 1.5L), a non VTEC equivalent, and a Z1 equivalent all marked "d15b". Then in 99 there was a Y7, Y8 (again, both are 1.5L instead of 1.6), and a 3 Stage VTEC "D15B".
The engine in your second link is a 1.5L equivalent of the D16Y7. You might as well get a D16Y8 for the same cost.
As previously stated, you can use a D16A6, OBD1 D15 non VTEC, or any OBD2 D series distributor on an OBD2 D series. Using the Z6 distributor is useful so you don't have to change your wiring. But if you get an OBD1 D series VTEC, then you have to use a Z6 or Z1 distributor and no other making them harder to find.
One last thing is that the Z1, Y7, and 3 Stage VTEC all have the cat converter right on the exhaust manifold whereas all the others have it after the collector. This manifold can be useful if you're going to go turbo because you can put the turbo right where the cat converter is and then reuse your cat converter in it's original location.
96-00 EK VTi = D15B OBD2 VTEC-E
But really, there are so many variants that the info we have just doesn't even begin to cover it.
Yeah I know! If only there was some kind of online encyclopedia that we could collaborate on...
http://en.wikipedia.org/wiki/Honda_D_engine
It better be... since I've had them all.
j/k
I've had a D16A6 equivalent ZC, a D16Z6 equivalent ZC, and a 3 Stage VTEC. In the junkyard there is a JDM D15Z1 equivalent D15B in a DX w/out VTEC-E wired up. When I was shopping for a 3 Stage, I picked through the D15B equivalents of the Y7, Y8, Z6, and B7. The importers don't know what they are. They only know if they're VTEC and what years they go to.
The JDM stuff is pretty easy to comprehend. The pacific islands and european stuff is all crazy. They go as low as 1.2 liters, w and w/out fuel injection etc. But depending on the exact country we're talking about, at least they have the specific engine code stamps similar to ours. That's how I found out that a 3 Stage VTEC is a D15Z7.
It would be helpful to track down the engine codes for the various "ZC"s and "D15B"s that were used outside of Japan.
I'm not cool. I'm just old.
