Replacing a passenger side axle boot?
I just took my wagon out rallying way too early in this morning, and I wasn't pushing it hard at all. Actually just driving regular doing like slow hill climbs. I took it back and on the way home it was squeaking really badly. I took the wheel off and looked and the passenger side axle boot was torn and there was fluid sprayed all through the back of the underside of the car. Every time I touch the brakes they squeak (rotationally, every time they hit a certain point in the wheel/rotor rotation they squeak loud). I now know that I need to replace the axle boot. What I need is: Steps to do so. Where to buy the part. And some advice on the squeaking! ...is it the axle? is it the brakes? is it just dust stuck between the pad and rotor? wheel bearing? i really have no idea what it could be.
http://honda-tech.com/showthread.php?p= ... ost3904833
the axle wouldnt squeel it would click.
go to oreily;s auto parts and get a replacement with a lifetime warrenty
When you're trying to pop the lower balljoint, it's a really good idea to spin the nut back on to protect the threads on the balljoint stud. One misplaced hammer blow, and you'll be cursing the air blue as you try and get the nut back on with the resulting damaged threads.
Chances are that if you really had a big mess of grease in there, the friction material on the brake pads is probably contaminated, so either soak the piss out of them with brake clean to try and clean them up, or sand them down some to get to clean material below, or just change them!
