Rear Suspension Hitting Bump Stops/ Bottoming Out
Question about rear suspension hitting bump stops and I am hoping some of you can help me resolve. I am currently running Ground Control Coilover kit ( 1991 Crx specs) with OTS spring rates mated to Koni Red shocks. I have the ride height front and rear set at about 1.5 finger gap. I am also running GC extended top hats in rear. The issue is that on sharp bumps I am still bottoming out in the rear. Fronts never bottom out on any bumps.
For those of you whom lower your car or even slammed them, is this an issue with you as well and you just live with it or is there a way to resolve this, other than raise the car?
Thanks!
Thanks!
Alternatively you could send you Koni's to whoever can strip them down and internally modify them to moved the operating area and revalve to suit your set up.
I run Koni yellows and whilst not slammed the rear constantly hits the bumpstops, ive run standard shocks and they were, for lack of a better description, f*cking horrible! Probably due to being old and worn but ugh, do not want.
I have some extended tophats to install at some stage which im certain will fix my problem of the bumpstops
Gonna try to find longer extended top hats. I don't weld so cant make my own. If anyone reading this has any customized, 'very' extended top hats they want to sell me, please let me know. Thanks!
Take your OEM ones into a engineering shop, or even exhaust shop.
They just need to cut the top off and weld a bit of pipe on then weld the top back on again. I got my brother to make some and he said it was easy as, hardest part was finding the right sized pipe.
just trim the bump stop down. my bump stop is about 3-4 inches. im just eye balling it. i can trim it down to maybe about 1inch. it will allow the system a bit more travel but i woulnt trim too much more after that.
