Need help finding a clutch kit
Hey everybody. I have searched google and some other places but am having conflicting numbers with the different clutch kits. I just bought my DOHC ZC for 250 bucks and am starting to buy the parts I need before I do the swap. So does anybody know what clutch kit will work in my 1989 RT4wd wagon? Hopefully something that will hold some more power. Thanks for any help guys, I know you will come through!!!!!!!
Also will the power steering and alternator bolt up to the ZC from my D16? These things weren't included with the motor.
Clutch should match your gearbox, not your engine..
Thanks pacifier.
This page should give you some ideas re: part numbers... but this is for the USDM Wagons... :?
Maybe try contacting ACT, they make clutch kits for the RT4WD.. http://www.jazzproparts.com/ProductDetails.asp?ProductCode=ACT%20HW3-HDR4
If that is the case you'll be able to mix and match to your hearts content.
Also to find out which one you need for your car call honda in germany and quote your chassis code and they will tell you what you need.
Honda made minor changes.There's a kit for'88,2 kits for'89 & 1 for '90-'91.If you buy seperate parts a lot of the parts are interchangable.
