What is the alternator exciter circuit ?
im about to change an intermitent alternator soon in my wagon.. and had read about an alternator exciter circuit, and fuse, and was wondering what it is, where the fuse is, and if it could have something to do with why my alternator seems to have an intermitant voltage regulator? If it wouldent have anything to do with it i will just go ahead and change the alternator.. but it would suck to get an alternator and find out it was a fuse somewhere causing the problem.
Does you charging light flicker as the rpms go up? If so, 99% sure that your brushes are worn out. They're dead easy to replace (you do have to take out the alternator), and they cost about $5 for a set.
