Help car will not start after it is warm!
Ok this is not an every day problem but it is becoming an issue. I have a 91 DX 1.5 auto. As I said in the subject line, after engine is warm it has trouble starting. If I run the car and get it up to temp shut it down for 1-3 minutes it will not start back up. I have to let it set for 5-10 minutes and then it will start. I am getting all my dash lights, I can hear my fuel pump prime, and then the starter just turns over but motor start.
This has happened twice in the past 24 hours. It has happened five or 6 times in the past 4 months but it seems to be happening more. Now remember it doe's not happen all the time and it only seems to happen when the motor is up to temp never when cold.
Any help would be great!
Thanks in advance.
Thanks in advance.
http://www.hondacivicwagon.com/bb/viewtopic.php?f=7&t=9644
Anyways thanks again.
If anyone else reading this has any other ideas what may be causing this please share.
Does it drive fine? Bog or anything? You don't happen to have a spare O2 sensor you could put in, do you? The oxygen sensor could have gotten clogged from your head gasket smoking and may need replaced. Just a thought.
The coil looks ok I cleaned it up when I was in the dizzy, could use a new one I guess. The ignitor is brand new I thought that was my problem when my head gasket was in the process of taking a dump.
Yes my check engine light comes on when my fuel pump primes.
No it runs great.
When I get back from vacation in a week and a half, I'll start with the main relay and replace my coil.
Thanks again all!
What you describe sounds more like a problem with the TW/ECT sensor. It is a two wire sensor under your distributor. They usually also throw a check engine code when they're bad, but not always. Check for codes and see if you have any. Code 6 (TW/ECT sensor) specifically is what I'm thinking...
this is what mine is doing as the light goes off ill hear a clicking sound. i guess ill have to go get a new on on saturday afternoon.
http://crxcommunity.com/viewtopic.php?f ... ay#p447964
One time I had basically the same problem and it wasn't the relay, or the O2 sensor, or the coil. After months of trying all of those things I finally pulled the ground wire to the distributor off of where it is mounted on the thermostat housing, sanded all the contact area, rebolted it, and that fixed it. Next time I will start with that before buying relays and sensors.
After getting some great pics I called Napa and Checker both with in a mile from me,they both had the part. So I went back out and started to pull the part out to do a simple test when I found that I did not have a socket set in this car, why would I it's a Honda.
I just like to say thanks to all of you here that had so much great input on this.
