Swap please help
i have an 89 2wd that i pulled the engine out of and im trying to put in a 93 jdm d15b obd1 with a p08 ecu.
my problem is the wiring. i cant find diagrams for eather car at least not the correct ones. the other thing is do i need a resister box for the injectors seeing as im going obd1. should i just use the d15b's harness or make the stock one work
Check our engine quicklinks...
viewtopic.php?f=7&t=4766
every swap i come accross seems like its for obd0 and has the resister box. would i just eleminate it and connect all the yellow and black wires together. and then contenue as normal
the only thing i still need is a downpipe that will fit the header that came with the d15b
