Pass. speaker working intermittantly
As the title says, my pass. side speaker works from time to time. I've swapped out the factory speakers with some pioneers which are working. I'm no radio wiring expert but judging from the fact that if I push up or down on the harness plug at the back of the head unit the pass. speaker works, means I have some loose wiring at the plug or my radio is FUBAR right? Will replacing the factory head unit fix this or do I still need to fix the wiring at the plug? Thanks in advance!
James
James
Did your read his thread or just the title?
Aftermarket radio companies will use the same plug for most of their line for many generations within that brand. So you could try getting another harness. That's most likely the problem that the pin connector is loose but there's no way for me to know without messing with it in person.
