MPFI blues...
so i'm almost a week into my MPFI swap.
that's right. a week.
everything is installed, all connections soldered and heat-shrunk (wire loomed and taped like o.e., too), but no start.
ecu throwing a code 4. TDC/CRANK/CYL sensor. go through the factory troubleshooting process, everything checks out - except the ecu. bad, bad ecu.
now i'm stuck trying to find another ecu - because i'm sure as hell not taking all this crap back off again.
no local salvage yards have any - but they can order one. for $150+, with no idea of when it would show up. nope, not going to do that. could go eBay route - in fact, i'm bidding on one now - but then i have to hope the new ecu is good, and i'm not getting screwed like last time.
argh.
just had to vent.
argh.
just had to vent.
did you get the si distributor?
* 88-91 Civic/CRX Si Complete Intake manifold w/Throttlebody and Injectors
* 88-91 Civic/CRX Si Complete Distributor(TD-02U)
* 88-91 Civic/CRX Si Complete Engine Wiring Harness
* 88-91 Civic/CRX Si Injector Resistor Box
* 88-91 Civic/CRX Si PM6 ECU
* 88-91 Civic/CRX Si Throttle Cable
Hopefully this is some help.
the ecu does some other funky stuff, too. it's a bad ecu, trust me.
