I have searched all over this forum and yes i used the search button. I was wondering if anyone could tell me how to remove the rear hatch supports. These are a lot different than whats on my 08 Scion XB.
Guess nobody knows how to do this? even tho its been done hundreds of times on this forum that i have seen. I just cant get the top part of the shock out of its mount. I did manage to get the bottom part off.
The top is the easy part. Pop off a plastic cover and there are 2 M6 bolts (10mm head). The bottom is a little tricky because you have to back the stud all the way out with a 12mm open-end wrench. Good news, though: since the aftermarket ones come with a detachable stud at the bottom, you can cut off the ball end of the old ones and take the rest out with a socket...make sense?
Where'd you buy your after market ones?
Advance Auto. They're 'Strong Arm' brand- don't recall the part number.
Okay so b4 i even had time to read this i found out that i ordered the wrong ones from work, hell i even work at advance (but they were not pictured right) the part# 4909 . I did excatly what bam-bam said b4 i was just confused but it was bc i had the wrong shocks. But this is very easy to do. I feel like a DA for asking.
http://shop.advanceautoparts.com/webapp ... 9341008___
You've got them installed already? Or just ordered? I'm buying these ASAP...
Yea I already have them installed, and they work great. only paid 27.99 for them.
